73 turbo swap - not starting
Robrob
73 240z
L28et from 82/83
Motor is stock.
Ok, I posted on ZCAR last week after I found my injectors were not squirting. Somebody helped me out and told me what wires should go where and I now have injectors that squirt, but I still can't get the thing to start.
I went back through and checked all of my connections and grounds to make sure everything is connected correctly and I also cleaned all of the contacts. After that I tried starting again. It sounds like one cylinder fires immediately as soon as I start cranking, but that's it, and it only fires once.
I swapped out the ignitor, and still nothing.
Does anybody have any suggestions?
Thanks
Fuel, spark.
Next timing. But check spark at the plug frist.
On a side note, why come here if Zcar was able to help you so far?
From my experience, I get quicker responses here on HybridZ. I wanted as many ideas as possible, and I found that for myself, it's easier to search here. Larger knowledge base on this forum, and less flaming compared to Zcar.
And thanks again. I do appreciate the help...from both forums.
