Zed2k Posted June 7, 2008 Share Posted June 7, 2008 Just wondered if anyone has the same thing going on my wideband shows 12.9:1 at idle but my megasquirt screen shows 13.9:1 looks like it's running like this across the scale cars going really well, but want to get the best out of it, maybe i should recalibrate the LM-1 and recheck as I don't want to be tuning wrong!! Can anyone give me a run down on the exhaust gas settings in mS1 extra + edis. What do you think!!?? Quote Link to comment Share on other sites More sharing options...
big-phil Posted June 7, 2008 Share Posted June 7, 2008 there is something in the manual about this. I think you need to make sure your grounds are all tied in at the same point as far a gauge, wideband, and MS?? Mine also reads a bit off, but not that much. Also make sure you chose your wideband under the car1 setup or one as close as possible. Its been awhile from when I went through this, so I can't remember everything. Quote Link to comment Share on other sites More sharing options...
Zed2k Posted June 7, 2008 Author Share Posted June 7, 2008 Thanks will ckeck it out, I saw in your last Vid you had shielded the fuel rail, did this help much? as mine is suffering from heat soak, when left for about 15 mins, runs really lean for a while, once started then is ok after a short while. Don't sell it!!! Quote Link to comment Share on other sites More sharing options...
big-phil Posted June 7, 2008 Share Posted June 7, 2008 Thanks will ckeck it out, I saw in your last Vid you had shielded the fuel rail, did this help much? as mine is suffering from heat soak, when left for about 15 mins, runs really lean for a while, once started then is ok after a short while. Don't sell it!!!not really. Its not as bad, but on a hot day after restarting it runs crappy and lean for a bit. I think I'm going to put the heat shield back under the intake? Quote Link to comment Share on other sites More sharing options...
datman Posted June 8, 2008 Share Posted June 8, 2008 Hi Nick, mine does this too but not as bad, I think its about 0.4 out. Like Big P said it's probably a ground issue unless you don't have the wideband output set right or the setting in MS right. I power mine from the Cig socket so I'm guessing that's why it's out a little. My first sensor just died giving an 04 pump cell error...I always forget to switch the thing on when I'm driving, I should really finish tuning the top areas of my fuel tables and take out the wideband. Are you going to take it to RWYB anytime soon? Quote Link to comment Share on other sites More sharing options...
Zed2k Posted June 8, 2008 Author Share Posted June 8, 2008 I have just got it flying as it seemed to be bogging down under boost and running out of steam I was running 10:1 on the wideband, have leaned it out now and she really flys, just a little worried, at least it's real reading is on the richer side than what Meagasquirt is showing. Quote Link to comment Share on other sites More sharing options...
X64v Posted June 8, 2008 Share Posted June 8, 2008 My LC-1 reads dead on in Megasquirt. Make sure they're grounded to the same point and have the correct settings in the Megatune configurator and you shouldn't have a problem. Quote Link to comment Share on other sites More sharing options...
Zed2k Posted June 8, 2008 Author Share Posted June 8, 2008 I have my configurator set to # set INNOVATE_0_5_LINEAR "Innovate, PLX 0-5V 10-20:1 AFR" to use my LM-1 is this right!! I suppose I could use LC-1 setting but it says displays lambda? Quote Link to comment Share on other sites More sharing options...
X64v Posted June 8, 2008 Share Posted June 8, 2008 Use the LC-1 setting, it still displays A/F. Quote Link to comment Share on other sites More sharing options...
Zed2k Posted June 8, 2008 Author Share Posted June 8, 2008 Ok will try that and check the grounds, and let you know the result. Quote Link to comment Share on other sites More sharing options...
Zed2k Posted June 9, 2008 Author Share Posted June 9, 2008 Ok have changed the grounds, I have soldered the 2 megasquirt and wideband together now the readings are pretty much spot on!! Thanks for that. now back to the tuning. Quote Link to comment Share on other sites More sharing options...
