Injector boss machining question
Derek
I'm setting up to machine the injector bosses on my EFI manifold and I'm a little confused (What else is new). Every web page I can find about making your own bosses for the bosch injectors has you boring a .540 hole or better.
One site
http://www.sdsefi.com/techinta.htm
has you boring a .640 to .650 hole through the boss then has you use an oring on the shoulder to seal the injector. This alows an air gap between the boss and the injector to cut down on heat transfer. I like the idea of this method but what concerns me is havening such a large hole into the intake. Won't this cause a ton of turbulence?
Thanks
Derek
  cygnusx1 said:
Wouldn't some turbulence help the fuel spread out better in the chamber? Don't mean to answer a question with a question. Sorry.
I was wondering that myself. It must not be a big problem as I can't find any posts regarding it on the web.
Derek
