gjc5500 Posted June 12, 2008 Share Posted June 12, 2008 so i broke a wheel stud and went to change it(ez to do right?). the drum will not come off. it is stuck to the hub and will not budge. ive tried prying, hammering, using a puller. if anyone has any info on how to get it off please let me know. Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted June 12, 2008 Share Posted June 12, 2008 You can try adjusting the shoes so that there is room bewteen them and the inside of the drum. I think the drum is aluminum so i don't think it's rusted on the hub although WD-40 might help. I used a small hammer or mallet and tapped the back of the drum all around on the fins. I don't remember if there was a threaded hole on the front face of the drum but, if there is just turn a bolt through it and it should come off. Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted June 12, 2008 Author Share Posted June 12, 2008 brakes are adjusted out. tried the hammer. no holes for a bolt Quote Link to comment Share on other sites More sharing options...
buZy Posted June 12, 2008 Share Posted June 12, 2008 Disconnect the parking brake cable too. Maybe it will release the shoes more. Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted June 12, 2008 Share Posted June 12, 2008 If the drum turns the brakes aren't holding it. Sounds like it's seized to the flange. Give it soaking of PB Blaster. Hit the drum on the face where it seats upon the flange using a lead or heavy rubber mallet to separate. Tapping from the side or back can damage the drum. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted June 14, 2008 Share Posted June 14, 2008 I sprayed mine with wd40 and left it for like an hour. That didn't work, so I heater the drum up with a torch. Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted June 16, 2008 Author Share Posted June 16, 2008 its fixed. took a dremel to the center of the hub and took all the burs off of it. came right off Quote Link to comment Share on other sites More sharing options...
AK-Z Posted June 17, 2008 Share Posted June 17, 2008 its fixed. took a dremel to the center of the hub and took all the burs off of it. came right off Haha. That's exactly what I did, but with a wire wheel. It was like 3 years ago when I had to do this, so I totally forgot . Just remembered beating on it and torching it . Quote Link to comment Share on other sites More sharing options...
