RB26240Z Posted June 26, 2008 Share Posted June 26, 2008 I searched and so far this is what I have found: -One post says Tomei recommended 15NM, which converted to ft/lbs is about 11, doesn't make sense! -another post says up to 86ft/lbs. -The ARP studs that I purchased from summit part number 202-4207, says "Following the manufacturers recommended torque sequence tighten the nuts in three equal steps to 125 ft/lbs with ARP MOLY ASSEMBLY LUBRICANT. I am using the cometic gasket, and would like to know if anyone has done this lately and remembers the torque specs. Thanks Quote Link to comment Share on other sites More sharing options...
stony Posted June 26, 2008 Share Posted June 26, 2008 I have JUN (ARP i believe) head studs a they emailed me back and said 85-90ftlbs. which is right around where the stockers are at. But let me verify by reading the email again when i get home Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted June 26, 2008 Share Posted June 26, 2008 http://forums.hybridz.org/showthread.php?t=132106 Further down the thread you will see the 15nm was for the conrods (then 60-65 degrees and measure the stretch) the specs on the headstuds are further down quoted by Careless. the specs he quoted are correct. Q Quote Link to comment Share on other sites More sharing options...
