exhaust gas sensor
vspec
He is right, all it will do is make the car run richer, which is just going to waste gas...
Why would you want to eliminate it?? With a good standalone system the O2 sensor is just going to help you out a Ton, not hurt you.. unless you are talking about eliminating the EGR system, which will not have a negative effect on your car.. just increase your throttle response some, maybe even make a better idle. ;P
