tclhenstra Posted June 27, 2008 Share Posted June 27, 2008 i was doing the intake/exhaust on my l28et today. and also fitting my n42 intake on and while the manifold was out i took the oil line to a local race shop here in town. anyways, long story short. the guy flipped out and wanted to rig something up because it was "some metric size" i dont know much about AN and NPT fittings and what not. but what would i need to get this line made from the turbo banjo bolt to the oil pressure sender? if anyone has any links to premade units i'd be interested. tony Quote Link to comment Share on other sites More sharing options...
z-ya Posted June 27, 2008 Share Posted June 27, 2008 Why not just use the stock line? From memory your need the following. I would double check before ordering anything. 12mm inverted flare to -4AN (at the pressure sender) 12mm banjo to -4AN (at turbo) 4 or so feet of -4 hose 2 -4AN swivel hose ends. Quote Link to comment Share on other sites More sharing options...
tclhenstra Posted June 27, 2008 Author Share Posted June 27, 2008 honestly ya, it's really just to clean up the bay some more. i'm going to need to do this again when i get my inline fuel rail so i figured i might as well get some practice. but i didnt think someone would make that big a deal of it. so i would need to tap an inverted flare fitting and a banjo bolt to run a -4 fitting through there? Quote Link to comment Share on other sites More sharing options...
z-ya Posted June 27, 2008 Share Posted June 27, 2008 You don't need to tap anything. Here are some hints: Or just buy one of those turbo oil line kits. Pete Quote Link to comment Share on other sites More sharing options...
slownrusty Posted June 27, 2008 Share Posted June 27, 2008 Do a search under my name (slownrusty) and you will see I detailed with many photos how to do this. Should be helpful and I did not use Banjo fittings with crush washers. Yasin Quote Link to comment Share on other sites More sharing options...
tclhenstra Posted June 27, 2008 Author Share Posted June 27, 2008 Do a search under my name (slownrusty) and you will see I detailed with many photos how to do this. Should be helpful and I did not use Banjo fittings with crush washers. Yasin yasin that's what i wanted to hear really. i found a "diy" on making them on nico but couldnt figure out the "key words" to get one on here. how hard was it? did you need any tools besides a cutting tool? tony Quote Link to comment Share on other sites More sharing options...
tclhenstra Posted June 27, 2008 Author Share Posted June 27, 2008 hey yasin. i typed in your name and nothing came up. i found the place i could get my an fittings from. but wasnt sure of the size. if you can post a link to that thread i'd be very thankful tony Quote Link to comment Share on other sites More sharing options...
X64v Posted June 28, 2008 Share Posted June 28, 2008 http://forums.hybridz.org/showthread.php?t=104828 I'm pretty sure that's the thread he's talking about. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted June 29, 2008 Share Posted June 29, 2008 http://forums.hybridz.org/showthread.php?t=104828 I'm pretty sure that's the thread he's talking about. Yup thats it! Yasin Quote Link to comment Share on other sites More sharing options...
