aziza z Posted July 8, 2008 Author Share Posted July 8, 2008 I did that. Ran a ridiculous size wire straight from the battery to the pump (guage 4), just to see if that was my problem. Fixed it for a couple of hours. But it came back. Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted July 8, 2008 Share Posted July 8, 2008 I did that. Ran a ridiculous size wire straight from the battery to the pump (guage 4), just to see if that was my problem. Fixed it for a couple of hours. But it came back. If that fixed it for a couple hours it sounds like its probably related...what was the voltage at the pump after rewiring it and then after it acted up again? Quote Link to comment Share on other sites More sharing options...
ragefear Posted July 8, 2008 Share Posted July 8, 2008 ummmm.... well, if it worked for a couple hours maybe its your alt that can't keep up. In those couple of hours it drained your battery more than your alt could keep up kinda thing. which could also be the reason why your voltage was so low in the first place... Quote Link to comment Share on other sites More sharing options...
aziza z Posted July 8, 2008 Author Share Posted July 8, 2008 Messed with it some more today. Its no longer lasting a couple hours. More like a minute or two. What I did is check the voltage while running. Its at 13.5v while running (58psi). And falls off in a matter of 20 seconds and continues to fall (yet voltage still stays at 13.5). And while pressure is falling the pump sounds like its dieing again. idk...... Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted July 9, 2008 Share Posted July 9, 2008 Messed with it some more today. Its no longer lasting a couple hours. More like a minute or two. What I did is check the voltage while running. Its at 13.5v while running (58psi). And falls off in a matter of 20 seconds and continues to fall (yet voltage still stays at 13.5). And while pressure is falling the pump sounds like its dieing again. idk...... Most likely a bad pump then. If it were a restriction in the system I would think you would see the pressure drop sooner. Its possible running it at the lower voltage may have caused it to fail prematurely. Quote Link to comment Share on other sites More sharing options...
aziza z Posted July 9, 2008 Author Share Posted July 9, 2008 I think what is going on is that i have a couple factors at the same time. My afr gauge is reading extremely rich (even though the fuel pressure is dropping). I think one of the injectors might be stuck open. This might explain why the system sometimes doesn't hold pressure after car is off (that a complete guess). Dont think that would explain my pump issue though. Quote Link to comment Share on other sites More sharing options...
ragefear Posted July 10, 2008 Share Posted July 10, 2008 damn, yea I would say its a bad pump. Hate to say it tho. Just buy another from summit and then put the old one back in the box and ship it back. what brand is your afr? I have come to the realization that you can't trust anything that isn't innovate... Quote Link to comment Share on other sites More sharing options...
Savage42 Posted July 10, 2008 Share Posted July 10, 2008 Yep, definitely sounds like a pump issue. Pumps typically drop off and have issues when they get warm. Quote Link to comment Share on other sites More sharing options...
aziza z Posted July 10, 2008 Author Share Posted July 10, 2008 The afr guage is from autometer. I havnt had a chance to check the injectors on that side of the sensor yet. Is there any easy way to check it without taking it off the car? My new pump is on its way. Quote Link to comment Share on other sites More sharing options...
bodie Posted July 11, 2008 Share Posted July 11, 2008 some of those pumps just make noise, no matter what you do you could swap for a new one and it may or may not make noise. Quote Link to comment Share on other sites More sharing options...
ragefear Posted July 11, 2008 Share Posted July 11, 2008 some of those pumps just make noise, no matter what you do you could swap for a new one and it may or may not make noise. yea, I agree but his is dying off after it warms up, its not supposed to do that! Quote Link to comment Share on other sites More sharing options...
aziza z Posted July 11, 2008 Author Share Posted July 11, 2008 yea, I agree but his is dying off after it warms up, its not supposed to do that! exactly. Dont really care about the noise. But the 40psi fuel pressure is a no no. Quote Link to comment Share on other sites More sharing options...
