Need Help (rough engine.) '79 280zx n/a
  • Replies 42
Merde alors...
Not sure the context of those words.
Now on to you, it is difficult to read and understand your approach to Z cars.
I typically stay away cause I just don't get it.
Now if google did me justice,,,, personally, not to happy right now concerning your comments.
What' up.
I've changed My Turbo injector for a rebuild n/a one.
Still dont run.
I've looked the spark plugs and no 1+2 are wet.(those have some''aftermarket''injectors.If i disconect there injector connector ,It does not changed the engine idle...still run like ♥♥♥♥...but at the same lvl of ♥♥♥♥.
SO those cyl. Dont work...in fact he run in 3 cyl.the 3 with stock injectors(green tops).
ah, so, since you've shown that those cylinders won't work with those injectors, have you switched the location of the injectors to see if the problem follows the injector as it moves to a different cylinder?
I thought I had a similar problem, except the problem didn't move from injector to injector. I found out that cylinder 3 was leaking out the exhaust valve very badly.
