rvandivort Posted July 21, 2008 Share Posted July 21, 2008 Hey guys,I`m sure this has been done before...but, is there a BOV on ebay that has the proper outlet to go to the input of an hy36w to cut down on lag. Thanks, Roger (I`ve seen some ovals and horns---want a tube for a vacuum line fitting). Or other manufacturer? Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 21, 2008 Author Share Posted July 21, 2008 Oops..hy35w! Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted July 25, 2008 Share Posted July 25, 2008 rvandivort said: Hey guys,I`m sure this has been done before...but, is there a BOV on ebay that has the proper outlet to go to the input of an hy36w to cut down on lag. Thanks, Roger (I`ve seen some ovals and horns---want a tube for a vacuum line fitting). Or other manufacturer? What fitting on the HY35? Most BOV's pipe into the intake pipe for the turbo. In that case, the piping has to be made yourself. Just get one (like the GReddy) that has a round outlet and have a pipe made to fit. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 29, 2008 Author Share Posted July 29, 2008 Hi Wizard Black Thanks, I was trying to get away from the hornblowers and go to the tubes. I realize some are going for the noise--over performance. So, that is why I asked. I appreciate Your response. Roger..any ones You could recommend on EBAY?? Quote Link to comment Share on other sites More sharing options...
Challenger Posted July 29, 2008 Share Posted July 29, 2008 Im not sure what you mean by "the proper outlet to go on the inlet". The BOV goes in between the turbo and the TB. Not on the inlet. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 29, 2008 Author Share Posted July 29, 2008 Hey Challenger, I`m trying to find a 1/4 " output (greddy type --I guess or others). I understand that the BOV goes before the inlet of the air regulater. Am trying to get a model that has an output that I can feed to the input of the turbo to keep the good times going--in other words-keep spinning the SOB!! Quote Link to comment Share on other sites More sharing options...
Challenger Posted July 29, 2008 Share Posted July 29, 2008 Your wanting to vent it to the turbo intake rather than to the atmosphere, correct? Ill go check my BOV to see what the outlet is. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 29, 2008 Author Share Posted July 29, 2008 Yeah that would be cool! Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 29, 2008 Author Share Posted July 29, 2008 I want to know what your outlet diameter is so I can throw it into the input of the turbo---assuming 1/4 inch. What BOV do You have. I can do 1/4 inch vacuum tube for this.Thanks, Roger Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted July 29, 2008 Share Posted July 29, 2008 Its called a recirculating bov. Any RS or S type bov can do it you just need the proper fittings. http://cgi.ebay.com/ebaymotors/BOV-TURBO-BLOW-OFF-VALVE-TYPE-RS-HONDA-INTEGRA-ACCORD_W0QQcmdZViewItemQQcategoryZ33742QQihZ006QQitemZ160264658537QQrdZ1QQsspagenameZWDVW This is all you need. and instead of letting it vent to the engine bay you run a hose from the outlet to the inlet to the turbo in between your air filter and your turbo inlet. Petty much any BOV that has a single outlet that has a horn or trumpet on it is normally threaded in and can be replaced with a fitting to connect a hose. This is the type you should be looking for Any of the RS or S types on ebay will work. you just have to get the correct fitting then. Some do come with it so just look for it. You really need to work on describing what your talking about and how you type things out. Until challenger deciphered what you where asking I doubt to many had a clue what you where talking about. It was the same way with your rotating the housing thread. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted July 29, 2008 Share Posted July 29, 2008 Also 1/4" vacuum line isnt going to be NEARLY big enough. If your only wanting to run 1/4" hose you might as well not even run a bov because it wont be able to vent fast enough to release any pressure. My BOV Has a 50mm piston that raises to release all the air. thats 2 inches. Most have an outlet size around an Inch to 1 1/4inches Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted July 29, 2008 Share Posted July 29, 2008 Search for forge motorsports blow off valves. I have mine recirculated. Evan Quote Link to comment Share on other sites More sharing options...
Pyro Posted July 29, 2008 Share Posted July 29, 2008 You need to recirculate if you are using a metered air flow efi system. 1" is the most common size. Bosch makes a cheap plastic one that works ok ($25.00). I used a turboXS unit on my car (120.00). You need to weld on short tube pieces on the lines going into the TB and the line into the turbo intake. Also, the flow should go smoothly into the intake line (in the direction of the flow). A simple 90 degree Tee is not the best way to do it. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted July 29, 2008 Share Posted July 29, 2008 I think he's a tad confused if he thinks the 1/4" hosebarb attachment on a compressor housing is to vent air to the turbo from a BOV. You need about 1.5" or more to vent it to a compressor intake pipe. You don't pipe it directly to the compressor housing (usually). Like I said, look at a GReddy Type-R or another that actually has a hosebeaded outlet that you can slip a hose onto. It isn't "air horn" style. If you want something that is straight up functional, get a TiAL. If you need a recirculating one, buy a Mitsubishi DSM BOV. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted August 2, 2008 Author Share Posted August 2, 2008 jeffer949, Thanks for the ebay info...but, only 11 bucks. Hard to believe!! Are You running it on Your machine? Sorry about My lack of proper description. Hell, blame it on My age. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted August 2, 2008 Author Share Posted August 2, 2008 Also, (and i`m a tad confused!) and thanks for the above help. Where do I get the fitting that goes between the air filter and intake? Is it custom? Wizard Black Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted August 2, 2008 Share Posted August 2, 2008 I was only giving an example. No im running a tial knock off from silliconintakes.com. It works great for me but would not for you because your wanting to recirculate yours and it doesnt have anyway to do that. And blaming ignorance and a lack of communication to what your trying to get across on your AGE is ridiculous. There is members on here that are 18 and under that communicate just fine with us "older folks" (im only 25 btw so its a joke) Quote Link to comment Share on other sites More sharing options...
rvandivort Posted August 2, 2008 Author Share Posted August 2, 2008 Hey jeffer949, I`m 60 and bought My 76 2+2 new. Don`t give Me bad stuff---just want information!! I don`t think in any way I have been not been truthful and accurate. I think that`s what it`s all about Quote Link to comment Share on other sites More sharing options...
rvandivort Posted August 4, 2008 Author Share Posted August 4, 2008 Sorry about that. Saw the joke later! I`ll go back on this thread and research a little more. I saw a system last year doing this and just was not satisfied with what I saw on ebay. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted August 4, 2008 Author Share Posted August 4, 2008 Jeffer949 if it works for You that`s cool. How long have You been running it? I certainly like the price! Quote Link to comment Share on other sites More sharing options...
