electrical problems
luvmy280zxt
Hows it goin everyone. I recently pulled my dash out to repair it. After re-installing it i found that my blinkers, clock, boost gauge, orange background lights, tail lights and side running lights wont work!! Im not an electrican by any means but I do know how to check fuses. I checked the fuse box in the car and all the fuses are good to go. What else could be the problem? Plz help and thanx!
You probably pulled a ground wire loose. They used barrel connectors under the dash and when one of them comes loose on a ground wire, a lot of different circuits using the common ground wire will not work. That would explain why you have problems all over the place. Look for a wire hanging that is not connected
