p90 head on a 77 block?
kvansic162
I want to make sure a p90 head will work on my 77 (used to have n47 head) block. I noticed 2 water jackets will be blocked by the head gasket. Will this cause a problem? Do I need to do anything special where those holes are?
use an 83 280zx turbo head gasket. and you should be good.
  • 5 years later...
The advice given in this thread is contrary to what I have read in other threads.
Could someone please confirm:
- if you have mismatched head and block, should the head gasket match the head (as indicated in this thread), or the block (as indicated) in other threads
