Miles Posted December 25, 2001 Share Posted December 25, 2001 My front differential mount is failing. Do I have to remove the differential to install a solid front mount or can I just pull off the front cross member to get at the bolts? Thanks Quote Link to comment Share on other sites More sharing options...
blueovalz Posted December 25, 2001 Share Posted December 25, 2001 Correct, no need to remove the differential. Quote Link to comment Share on other sites More sharing options...
Miles Posted December 31, 2001 Author Share Posted December 31, 2001 Having trouble getting to the nuts on top of the diff front mount. I can barely get an open end wrench on the bolts heads at the bottom of the mount. I removed the front cross member and left a jack under the rear end to keep things lined up. Should I remove the drive shaft and the jack and just let the diff hang off the rear mount. The last one of these I did with the diff out of the car. Trying to minimize downtime as this is my daily driver. Thanks Miles Quote Link to comment Share on other sites More sharing options...
