redneck1545 Posted August 23, 2008 Share Posted August 23, 2008 I have a early 260z and found these koni red's i was thinkin about buying... part #8641-1036 9012. I'm wanting to do a coil over setup in the future...can these be used on a coil over setup??? I dont have a problem with sectioning the strut tubes or anything but i dont want to buy shocks now only to have to buy different ones when i go with coil overs... I've searched for hours for an answer and haven't found one so hopefully i can get some help on this subject! Thanks Quote Link to comment Share on other sites More sharing options...
johnc Posted August 23, 2008 Share Posted August 23, 2008 I don't know what application that shock is for. Here are some general 240Z shock dimensions that can help you figure it out: 1. Travel: 5 to 6" 2. Shock body OD: 1.70" or less. 3. Shock body length: 12" to 14" That still doesn't help with valving. Quote Link to comment Share on other sites More sharing options...
redneck1545 Posted August 23, 2008 Author Share Posted August 23, 2008 thanks John, quite simply, if you dont know what application these number will work for, i should hold out for some that are certain to work. I trust your judgement and knowledge!!! thanks Quote Link to comment Share on other sites More sharing options...
redneck1545 Posted August 24, 2008 Author Share Posted August 24, 2008 just was told there was a typo and the part numbers are 8641 1034...i'm told they are fully adjustable (dual adjustment??) used but with less than 2k on them...good rebound, no leaks yadda yadda...would this be a good buy for a couple hundred for a set of 4???? wisdom is seeked!!! Quote Link to comment Share on other sites More sharing options...
srgunz Posted August 24, 2008 Share Posted August 24, 2008 For 1970 240Z to early 1974 260Z. The correct part numbers are 8641-1031 front and 8641-1032 rear. I have no idea what that number you have is for. I paid $430.00 for all four. And that was 15 years ago. They still work like the day I put them in. Quote Link to comment Share on other sites More sharing options...
redneck1545 Posted August 24, 2008 Author Share Posted August 24, 2008 well i havent bought them yet...and somewhere on here there is a write-up on how the 280z koni's inserts will work in a 240z style strut housing...i read it somewhere but cant find it again...but my plans are to section the struts and add a adjustable coil-over kit to the struts....I just dont wanna buy these things if they wont work with the type of setup im trying to end up with(when the pockets are finally deep enough) Quote Link to comment Share on other sites More sharing options...
johnc Posted August 24, 2008 Share Posted August 24, 2008 1034s are rear Koni shocks for the 280Z. They are single adjustable and are an obsolete part but you can still find them new on closeout from $125 to $150 each. I would pass on these shocks. Quote Link to comment Share on other sites More sharing options...
sticky280zx Posted August 24, 2008 Share Posted August 24, 2008 im already buying the ones in the for sale section if those are what you were looking at....and they work on 280z's if you type the part number in google it comes up 280z Quote Link to comment Share on other sites More sharing options...
redneck1545 Posted August 24, 2008 Author Share Posted August 24, 2008 yep those were the ones...i was just tryin to figure outif they would fit in the 240z style tubes...but SOMEONE had to get there hands on em before i could!!!! : ) anyways thanks everyone for tryin to help and i hope they work for ya sticky280zx Quote Link to comment Share on other sites More sharing options...
sticky280zx Posted August 25, 2008 Share Posted August 25, 2008 haha i pmed him dayyyys ago....i actually bought the set of hps with red sprins too lol but yes they are going to a good home...my shell...and g/fs 1st car...a 77 280z with nooo rust and pearl white paint (prev owner was restoring) for 750 but the easiest way to adapt is just buy the rear shocks tube/spindles/ full rear suspension from a 280z that way you get the r200 also Quote Link to comment Share on other sites More sharing options...
