Guest mtj71Z Posted January 23, 2002 Share Posted January 23, 2002 i have a 327 from a 66' caprice. will other 327 engine bellhousings work? thanks. mike Quote Link to comment Share on other sites More sharing options...
pparaska Posted January 23, 2002 Share Posted January 23, 2002 I think any 327 bellhousing should work, except for maybe the Chevy II version, but those are as rare as hen's teeth, I'd imagine. What are you bolting to it, tranny wise? Quote Link to comment Share on other sites More sharing options...
Guest mtj71Z Posted January 24, 2002 Share Posted January 24, 2002 a muncie i got a longtail so maybe it will help put the shifter closer to stock position? what do you think? Quote Link to comment Share on other sites More sharing options...
pparaska Posted January 25, 2002 Share Posted January 25, 2002 The muncie, if made for an old GM, ought to bolt right up to any 327 bellhousing. I didn't know there was a long tail muncie - that ought to be a big help, if not TOO long. Quote Link to comment Share on other sites More sharing options...
fl327 Posted January 25, 2002 Share Posted January 25, 2002 that long tail muncie might be a saginaw, good trans to but blows up before muncie.... Quote Link to comment Share on other sites More sharing options...
Guest mtj71Z Posted January 25, 2002 Share Posted January 25, 2002 "This is a muncie M21 4 sp tranny that is date code on main case sept 14 1967 date code ( P7P14 ) The case appears to be correct for 1967 gto lemans chevelle nova firebird camaro corvette from the info I had found on some muncie web sites. the tail housing seems to be from 64 65 CATALINA LONG TAIL" think it will work ? thx for the input.... Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted January 25, 2002 Share Posted January 25, 2002 here guys this may help, http://www.4speeds.com/muncie2.htm http://www.peachstatechevelles.com/muncieid.html http://www.dalesplace.com/htm/information/rpm_calculator.htm http://www.cloudmaster.com/cloudmaster/speed.html http://www.interlog.com/~muncie/history.html http://www.yearone.com/live/Id_info/trans_id.htm http://www.geocities.com/z28esser/muncie.html http://www.nastyz28.com/transid.html http://www.geocities.com/z28esser/ratio.html Quote Link to comment Share on other sites More sharing options...
