How do you refill 260z Manual Transmission?
Posey55
I searched the entire website, my haynes manual, my transmission and online but still cant figure out how to refill the transmission.
I have a 260z with the standard 4 speed; i searched the entire drivers and passenger side of the tranny but still couldnt fing where to refill it at.
If someone could tell me or put a icture of where its at it would be greatly appreciated.
Or, to do it without a pump, you can get a piece of 1/2" copper tubing about 3 feet long with a 90 degree fitting on one end. The 90 goes into the trans with the lengh of pipe going up through the engine comartment. From there you can insert a funnel into the pipe and fill with gear lube. It takes a while but it works.
I've done it by two different methods. The first time I bought a long piece of clear pvc tubing at the hardware store. I made sure it was the largest diameter that would fit in the fill hole. I filled it from the top using a funnel to get the gear oil into the tube, and consequently down into the tranny.
The other method I used was a pump. The pump had a piece of pvc tube on the end, so it was the same basic principal, but I was filling it from below the car.
Thanks for all the help but idk how big of a pain in the ass it will be to get off. I tried getting that 17mm off on the rear differential and that didnt work at all eve w/ a hammer. So i guess ill be taking the moustache bar off so i can get to it w/ a 19mm 12 point socket.
While on the subject of the driveline i was curious to know what size bolt i should use for the drive shaft because the other day i notice mines wasnt connected and there was no site of the original bolts.
