vq35de 350z and vq35de pathfinder (motor mount?)
ReefsRocket
I do not like to post threads at all but i could not find this answer anywhere I looked.
SIMPLE question,Are the mounting points the same on each block?
I found an engine at a friends junk yard,If i wanted to build a vq35de should i use the pathfinder block to save some money?
FEEL FREE to delete this post after its 60secs of fame!
  • 5 months later...
yeah the mounts are different, the pathfinder mounts sit the engine higher than the Z mounts. they bolt on so they're easy to change. You might also look at maxima mounts, they're similar to the Z, but the rear is pretty different. I dunno about G35..
