Fuel Injector hose form fuel rail to injector
jacob80
Hey guys, has anyone else had problems taking this fuel line off? It was tough just separating the injector and hose section from the fuel rail, but getting the hose off the injector is nearly impossible. I've tried side cuts and got it down to about 1/8 of an inch and now I cant get it off. What should I do about these stubborn hoses?
Grab the injector hose with a pair of visegrips as gently as possible and twist the line back and forth on the rail until it breaks free. You should be able to pull it right off then . It worked for me, but I wasn't going to reuse the injectors I was taking off. If you plan to reuse them go slow and easy so you don't tear up the fuel hose coming out of the injectors too bad.
