Lower Spindle too Wide for Control Arm..
You mean... this thing?
I'm about to go through the ordeal myself. I've been using atlanticz's writeup for reference, and so far its helped me out pretty well. He says somewhere in there that he had to sand both bushings down a little in order to fit his in. I was also thinking of blasting mine with CO2 or freezing them a little, but I'm crossing my fingers that it will just fit on the first try!
Yes. I got the one side in with aloooottttt of prying. I cant fit the pin in yet, but its progress.
Bolt it all up and feel how much resistance there is in that joint alone. Then reconsider shaving the bushing down to reduce that resistance. Might think about putting zerks in the end of the control arm too so you can keep them lubed. Doesn't work on the inside bushings, but it does on the outside bushings.
  • 1 month later...
