trigger angle question
big-phil
You need to look at the timing that MS is screaming at you with that HUGE number in the trigger wizard and confirm that number on the timing pulley with a timing light (with the engine warmed up). The trigger angle number should be adjusted until the BIG number and your pulley marks agree under a timing light. Mine was -60 when I used the 83 dizzy but yours could be different...I suppose. Dont worry about the number. Just make sure the MS# matches the pulley.
