VDO tacho/speedo electronic Cockpit series(look reasonably close to originals)
If fitting a more modern engine that runs the speedo/tacho off the ECU, but still want to keep the original look, VDO cockpit series are an easy, near drop in fit that look reasonably close to originals.
Tacho's come in 8000RPM,10,000RPM, speedo's 120MPH,160MPH and 200KPH and 300KPH(I used the 8000RPM and 200KPH, as I have no great need to be in a 30 year old Datsun at 10K on the tacho, with 160MPH showing-don't have a death wish thing going)
Real easy to set up, no difficult brackets /clips etc.
Detail and pic's on the link.click on pic's for full description.
http://www.flickr.com/photos/russjz-zed/sets/72157608024374696/detail/
  • 2 months later...
Part number link,DRZ man, and the person who's message I somehow deleted before got to reply to.
The link to pic's of install in first post is now obsolete, use the link to my build at the bottom of that post (and this one)VDO Install pic's, and easy to follow,idiot proof instructions are in there, on about page 3.
below are links to spec's.
Speedo.(MPH)
http://usa.vdo.com/products_solutions/cars/performance-instruments/vdo-performance-instruments/instrument-series/cockpit/speedometers/speedometers+-cockpit.htm
http://www.egauges.com/vdo_mult.asp?Type=Speedometer&Series=Cockpit&Units=E
tacho.
http://usa.vdo.com/products_solutions/cars/performance-instruments/vdo-performance-instruments/instrument-series/cockpit/tachometers/tachometers+-cockpit.htm
VDO range,and some prices
http://www.idee-systems.nl/Documenten/Layout%20VDO%20instruments%20uk%20final2.pdf
My mistake, seems that there is a 100mm version. You must have used that one as I can still see some of the bezel.
These part numbers off the boxes,
It is the 100mm version. part number for the 200 kilometre PH is
437 015 029. (obviously different numbers for the 300KPH and 120 MPH and 160MPH)
matching tacho 8000RPM is 333 015 034. also 10,000rpm available
