TexasZX Posted October 18, 2008 Share Posted October 18, 2008 Hey all I just recently got done putting a waterpump in my 83 280zxt and ripping out the ac. And now it's idling really rough, we had to move the maf to get down to the compressor and removed the bracket in the process. It sounds like it has a vacuum leak but I've checked every hose I can find. Is it possible that my maf is bad? What do y'all think this might be? Edit: I forgot to add when you add throttle it backfires into the intake... Quote Link to comment Share on other sites More sharing options...
Guest dghere Posted October 19, 2008 Share Posted October 19, 2008 did you cheack the rubber boot conection between MAF and intake manifold or for cracks in the rubber Quote Link to comment Share on other sites More sharing options...
tpnorth Posted October 19, 2008 Share Posted October 19, 2008 sorry to go off topic but how hard was the water pump i gotta replace mine? Quote Link to comment Share on other sites More sharing options...
TexasZX Posted October 19, 2008 Author Share Posted October 19, 2008 If you have basic skills with tools then it shouldn't be too hard... Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted October 20, 2008 Share Posted October 20, 2008 make sure the connector went back on the maf properly and is clean and free corrosion. Plug in out a couple times to be sure. Quote Link to comment Share on other sites More sharing options...
tec280zx Posted October 23, 2008 Share Posted October 23, 2008 Be sure to check all your connections, especially the cylinder head temp sensor in the thermostat housing. That cause a lot of problems if the connection is poor or the sensor is just bad. Quote Link to comment Share on other sites More sharing options...
