S15 200sx owner Posted November 5, 2008 Share Posted November 5, 2008 Hi guys, Well finally the 240 is in the panel shop having the frame rails fully replaced. The cross member that runs accross at the very front of the frame rails is in very bad shape, we have cut it right out at this point of the job, and it is really beyond repair. My question is can i replace it with a straight piece of tube, as the stock member has a step down in it. Is this step down needed? what is its purpose? Hopefully we can replace with a straight tube, as this will be so much easier. Note: my car is a race car, that will be far from stock, so will not be using the stock radiator or anything. Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted November 5, 2008 Share Posted November 5, 2008 You mean like this? Quote Link to comment Share on other sites More sharing options...
S15 200sx owner Posted November 5, 2008 Author Share Posted November 5, 2008 Exactly! Those frame rails dont look like the stock ones either. That is a trick looking piece of kit! Please share more pics and specs of your whole setup. Clint. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted November 5, 2008 Share Posted November 5, 2008 Also, depending on which engine you use, nothing says that the crossmember has to be at the front of the frame. Because I wanted to angle my radiator, and because I have a Ford V8 in a very set-back location, I elected to move my crossmember back even with the sway bar mounts. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted November 5, 2008 Share Posted November 5, 2008 This is how Roddy at Speed Design, Inc did mine. (Shamless plug) Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 5, 2008 Share Posted November 5, 2008 mayolives.. i love your car.. jeesh. so purrty all around Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted November 5, 2008 Share Posted November 5, 2008 Exactly! Those frame rails dont look like the stock ones either. That is a trick looking piece of kit! Please share more pics and specs of your whole setup. Clint. The frame rails are 2.5 x .125'' square tubing. If you want more info about the frame work I did see this thread : http://forums.hybridz.org/showthread.php?t=125985&highlight=chassis+stiffening Also, as David mentioned you don't have to place the member in the front. Now that I have so much room in front of the engine I actually could have placed the front peice alot further back. Here are some pics with my previous engine which should fit very similarly to yours. If your still going to be using your RB running the cross member in front might be your best option. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 5, 2008 Share Posted November 5, 2008 mayolives, that is beautiful.... You and emwhyrohen did a good job with a different core support setup. I'm young and work at a body shop, so obviously i hang around all the local street racing. You should see some of the hack jobs people do just to act like they know they're stuff. nicely done. Quote Link to comment Share on other sites More sharing options...
S15 200sx owner Posted November 5, 2008 Author Share Posted November 5, 2008 Thanks very much guys, its good to see your different ways of doing things. All look very good by the way. Giving me some good ideas. Cheers. Quote Link to comment Share on other sites More sharing options...
S15 200sx owner Posted November 5, 2008 Author Share Posted November 5, 2008 The frame rails are 2.5 x .125'' square tubing. If you want more info about the frame work I did see this thread : http://forums.hybridz.org/showthread.php?t=125985&highlight=chassis+stiffening Also, as David mentioned you don't have to place the member in the front. Now that I have so much room in front of the engine I actually could have placed the front peice alot further back. Here are some pics with my previous engine which should fit very similarly to yours. If your still going to be using your RB running the cross member in front might be your best option. Thanks for those pics, good to see it all with the RB in place, to get an idea of clearance etc. Quote Link to comment Share on other sites More sharing options...
