OK I'm stumped
Dragonfly
I've got a 72' 240z and I just picked up a BW T5 transmision for it, when I went to put it in I found that the mount on the transmission is about 1 inch further back than the bracket in the tunnel. I compared the mount that was on the tranny with the mount that I had on my previous tranny and there is about 1 inch offset between them, I am not able to use the one that came with the T5 as the bracket in my transmission tunnel is different.
I know I am not the first one to have this problem so if someone else who has gone through this before can let me know what you did I will be grateful.
Thanks
Dragonfly
:D:D:D
Yep, you found it. I used the crossmember from a 280ZXT with an automatic (don't know if it's the same as the manual ZXT), but I still had to slot the holes in the transmission and the tranny mount to accomodate it. Don't know what driveshaft issues there are, as I had a custom one built for about $200.
