Zed2k Posted December 9, 2008 Share Posted December 9, 2008 Just thought I'd start a thread on L28 Turbo 's for abit of research before I head back to the rolling road, If we can post Boost Air fuel ratio under boost, max timing acheived and water/ meth yes or No intercooler, yes or No This might give people and me an idea of what can be expected at which boost level etc , bhp (if known) 11.0 Afr 24 degrees water/meth yes (but not tuned for yet) Intercooler yes 15psi 315bhp Thanks. Quote Link to comment Share on other sites More sharing options...
ktm Posted December 10, 2008 Share Posted December 10, 2008 Simply look at the Megasquirt Map sharing thread. You can see target AFRs and some timing maps, all of which are plotted across RPM and manifold pressure. Are you running an AFR of 11 at 5 psi? 2 psi? If not, then when do you switch? What ratio of water and meth? 50/50? 80/20? There is more to this than simply Yes/No. Quote Link to comment Share on other sites More sharing options...
Zed2k Posted December 10, 2008 Author Share Posted December 10, 2008 11 at 15psi and water/methy 50/50 but I will checkout the map sharing threads just thought It might be clearer on a seperate thread if not don't worry.. Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 20, 2008 Share Posted December 20, 2008 This might give people and me an idea of what can be expected at which boost level etc , bhp (if known) This greatly depends on the turbo used. For an example, for me 15 psi is around 350-360 rwhp. Quote Link to comment Share on other sites More sharing options...
Kash Posted January 5, 2009 Share Posted January 5, 2009 compression ratio would be great to know also... Quote Link to comment Share on other sites More sharing options...
Zed2k Posted January 5, 2009 Author Share Posted January 5, 2009 My compression ratio is 8.8:1 Quote Link to comment Share on other sites More sharing options...
