fast-datsun Posted December 10, 2008 Share Posted December 10, 2008 We have complete our kit for the install of the VG30TT trans into the Z cars with the L- motor and completed testing, kit parts are : adapter, trans crossmember/w Poly trans mount, speedo sensor(cable), shifter and bracket(gets shifter very close to stock location) drive shaft and machined bellhousing (exchange). available as kit or seperate....require no mods to body or starter. Very easy to install as easy as stock trans swap...NEW 96 TT trans available. Mack sales@mckinneymotorsports.com Quote Link to comment Share on other sites More sharing options...
1 fast z Posted December 10, 2008 Share Posted December 10, 2008 Vendors forum??? Is it cheaper than 500.00? Quote Link to comment Share on other sites More sharing options...
CArFAn Posted December 10, 2008 Share Posted December 10, 2008 I couldn't understand what you wrote, but i re-wrote it so i could. Mabey others can to. We have completed our kit for the installation of a VG30TT transmission into the S30 chassis using the L series motor. We have completed our testing. This kit includes the following parts : adapter, trans crossmember /w Poly trans mount, speedometer sensor(cable), shifter and bracket (postions shifter close to stock location) drive shaft and machined bellhousing (exchange). available as kit or seperate....Requires no modifications to the body or starter. Very easy to install, easy as a stock transmission swap...NEW 96 TT transmissions available. Quote Link to comment Share on other sites More sharing options...
fast-datsun Posted December 16, 2008 Author Share Posted December 16, 2008 thank you!!!!!!! parts up on web site now... Quote Link to comment Share on other sites More sharing options...
