New Hoosier Tire
I deg to biffer :wink: Here is a short tire on an autox Z:
That is a 23" tall tire on a 13 x 13 rim. The front tires that go with it are 20" tall. The 15 x 11.5" x 23.5" FA slicks I'm going to run are also quite a bit shorter than the 18 in question.
For an 18 its a short tire, I'll agree with you there. I'm still convinced that an 18 isn't the way to go, especially on an S30.
Its a bit tall for an autocross tire on an S30 but it would work as a track tire. I ran 25.2" tall tires on the ROD and, although some compromises were required, it worked well. If the rules allow suspension mounting point relocation then tire OD is less of an issue.
