Questions on CenterForce clutch pack
Guest Widebodys30
Guest Widebodys30
TY for reading.
One of the motors I bought Has A Dual Friction clutch plate on it already.
I'd like to use it, if it is worth re-using.
My questions are:
1) Does it require a special release bearing?
There is some minor damage to the release fingers,
and I was wondering if it was caused by an improper R/B,
or maybe the slave or master cyls. going south(my guess).
2) Has anyone had any issues or complaints about using them?
I tried to search, but No luck.
TY...
I have one that I put in a little while ago due to the front seal pucking all over my new setup and ruining my clutch. I used a stock pressure plate but a modified disk with composite pucks on the pressure plate side. I put this centerforce in and I am not very pleased with it. I can tell it is slipping just by the way it acts. Before I would be sideways after shifting into second during WOT and under boost with my last setup. This clutch setup, Noop. Buy something else. I will be looking in the future.
Guest Widebodys30
Thanks for sharing your real world experiences.
Seems that CF DF clutches are more hype than anything.
I guess it wouldn't matter too much with my N/A mikuni carb build,
as it will be kinda mild compared to some motors out there.
But I have heard way too many negative things about them slipping early.
I'll be going another route, myself,
even though I have one right there on the 2.8L N42/N42 engine I bought.
Thanks...
