280z4me2 Posted December 30, 2008 Share Posted December 30, 2008 I went to start it this morning and got no reading from the battery gauge and car had no power. I figured the battery was dead so I tried to jump it off. When I sat in the Z, I noticed it was smoking really bad from the battery side. It was thoughs two white square boxes in front of the battery(on the firewall). Both were smoking REALLY bad. What are these white boxes and what would this mean? Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 30, 2008 Share Posted December 30, 2008 Fuse (aka fusible) links. Pop the plastic covers off and you will probably see some melted wires. Did the + jumper cable whack the body ground anywhere? Did you hook the jumper cables up correctly? Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted December 30, 2008 Author Share Posted December 30, 2008 I took off the plastic covers and one of the wires was corroded VERY badly and just crumbled when I touched it. I checked the battery and the battery is dead. Would this bad wire cause the battery to die while the cars not running? I just replaced that wire but havent tried jumping it again. Also, while im at it. I have tried to jump this car off before and when I took off the jumper cables, the car would die. I then jumped it with another car battery and when I removed the connector, the car shut off. Does this mean my alternator is bad or are these cars designed with the battery cables being the main curcait? Quote Link to comment Share on other sites More sharing options...
naviathan Posted December 30, 2008 Share Posted December 30, 2008 Z cars will not run when one of the battery cables are removed. It kills the field in the alternator. As for the links and the dead battery; Sounds to me like you need a new battery and new fusible links. Or upgrade the links to the maxi fuse box. Quote Link to comment Share on other sites More sharing options...
nelson rodriguez Posted December 30, 2008 Share Posted December 30, 2008 yeah i had a loose one a month or so ago, and it caused a short and all my light bulbs blew out. so make sure when you put the new fuse links that they are tight. squeeze the plugs on the links a little that will help. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted December 30, 2008 Author Share Posted December 30, 2008 The battery is new. Mabey a month old. I just went and jump started it. I let it run a few seconds. When I unplug the jumper cables, the engine revs down and starts a puddering motion. I jumped in the car to give it a little gas and there was noises under the hood that sounded like a light bulb was blowing out(the car doesnt have bulbs in it so its got to be a solenoid or something). Any idea what these noises were? The battery gauge now reads half way so the alternator is working I suppose. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted December 31, 2008 Author Share Posted December 31, 2008 Anyone got any idea? Quote Link to comment Share on other sites More sharing options...
uefa5 Posted December 31, 2008 Share Posted December 31, 2008 your battery gauge should be showing above 14v or very close to it if your alternator is working properly Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 31, 2008 Share Posted December 31, 2008 280z4me2 said: Anyone got any idea? Start digging for damage....... Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted January 1, 2009 Author Share Posted January 1, 2009 I found a write up, Thanks! Quote Link to comment Share on other sites More sharing options...
