260Z alternator upgrade
Is there a kit available? I've looked on MSA, but the one on their site says it's for the 240Z. Is there a diagram or something that shows how to use a regular, newer alternator like off of a SBC so you can bypass the external regulator? I'm sure I could fab up some brackets for one, I'm just not sure how to bypass the external regulator. I'm sure someone has done this before. :confused2
Sorry to say, but neither of those ideas will work on a 260Z. The bastard stepchild has an external shunt and the seatbelt interlock system that will not let you do it the easy way. I am still looking for a final consensus on how to do it.
My 260Z doesn't have the seatbelt interlock. It can be started whether you're sitting in the seat or not. I'm guessing the previous owner had it disabled somehow.
1 wire 105 amp alternator from summit 100 dollars peace of mind from 1 wire alternator,priceless.lol I hooked red and white wire to alternator and thats all .the seat belt interlock has to do with the starter relay you use the black and yellow wire instead of the white one that originaly went to the starter by the way summit sells brackets for the alt too,B
