chicago240z Posted January 5, 2009 Share Posted January 5, 2009 Ive been piecing together a turbo kit for my 240z ill be running a f54 block, there is alot of info but no recommendations what would be a good turbo for around 350-400 h.p. ive been looking at the garrett t3/t4 models but have no clue which one to buy. I want very little lag and dont need to rev it to 8k 6k is plentyand to have it kick in around 2500-3000 rpm any suggestions with explanation of them would be greatly appreciated THANKS CHICAGO240Z Quote Link to comment Share on other sites More sharing options...
nismopick Posted January 5, 2009 Share Posted January 5, 2009 Not many recommendations because the options are MANY. How much do you want to spend? Quote Link to comment Share on other sites More sharing options...
Pyro Posted January 5, 2009 Share Posted January 5, 2009 A TO4E-50 trim is a good compressor for a L28. But it will need a 1/2 inch spacer to clear the manifold. If you are going to use the stock cam then use a stock L28 T3 turbine if you plan to use an aftermarket cam then open up the turbine a little to a stage 3 or so. However, a free flow turbine will make a boost come on later. So it sounds like a stock turbine will be best for you needs. (t3 0.63a/r). to make 350hp at the crank (300 at the wheels) then you will need about 20 psi of boost with a stock cam and a aftermarket efi system. Quote Link to comment Share on other sites More sharing options...
