Guest Thurem Posted August 18, 2002 Share Posted August 18, 2002 Which is better billet steel or cast iron? Both are available for SBC in the 15 to 18 # range. I have a centerforce dualfriction clutchdisc to go behind it. The car is gonna be streetdriven. Thure Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 18, 2002 Share Posted August 18, 2002 You must mean Nodular Iron (GM). It's a pretty light piece - I have that in my car. If you have the bucks, do billet - stronger. Plus it'll likely be SFI rated, if that's important to you. Personally, with my lumpy cam, I kind of wonder if a heavier flywheel would have been better. Quote Link to comment Share on other sites More sharing options...
Mike C Posted August 19, 2002 Share Posted August 19, 2002 The main question in my mind is how high are you turning the motor? Anything about 5k rpm or so and I wouldn't even consider the nodular iron 'wheel unless you are running a scattershield. Usually if I decide to buy a part new, I'll go for the best part I can get, ie the steel flywheel. If I have one lying around, I'll use it. Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted August 19, 2002 Share Posted August 19, 2002 The reason for the question is: Flatlander Racing has a Nodular 15# for 140 and a Billet steel 18# for 130$, Both are Proline brand. But is the consensus that billet is safer for high Rpm, then? And what about wear, is that an issue? Thure Quote Link to comment Share on other sites More sharing options...
Mike C Posted August 20, 2002 Share Posted August 20, 2002 Steel is more likely to bend than explode. As far as wear goes, the steel is a more dense material and with the some surfacing/disc I would think it would last longer than the nodular. Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted August 20, 2002 Share Posted August 20, 2002 Go with the billet... it's trick dood I got a billet steel one from eBay for about a hundred bucks, brand new, don't know the brand but it's beautiful and I trust it... sixteen pounds Quote Link to comment Share on other sites More sharing options...
