zx beast Posted January 8, 2009 Share Posted January 8, 2009 Will wheel that fit on a honda fit on a z? they are both 4 by 100, and look to be about the same... will it work? It is easier to find honda wheels lol:grin: Quote Link to comment Share on other sites More sharing options...
blue72 Posted January 8, 2009 Share Posted January 8, 2009 Only if they happen to have the same offset and the centers of the rims are large enough to fit over the hub dust caps on the Z. Otherwise you'll need some thick spacers. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 8, 2009 Share Posted January 8, 2009 http://www.modern-motorsports.com/catalog/product_info.php?manufacturers_id=&products_id=6 Quote Link to comment Share on other sites More sharing options...
jerryb Posted January 8, 2009 Share Posted January 8, 2009 I use those...well made! Quote Link to comment Share on other sites More sharing options...
NCchris Posted January 8, 2009 Share Posted January 8, 2009 they are both 4 by 100, and look to be about the same... will it work? It is easier to find honda wheels lol:grin: Incorrect! Honda is 4 X 100mm Zcar is 4 X 114.3 Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted January 8, 2009 Share Posted January 8, 2009 Some Honda are 4 x 114.3 I know because I ran a set of wheels on my 94 Accord and also on my 240Z. I have a set of MML spacers Ross made for me for this application. I no longer need them. PM me if you're interested in these spacers. Quote Link to comment Share on other sites More sharing options...
NCchris Posted January 8, 2009 Share Posted January 8, 2009 Some Honda are 4 x 114.3 I know because I ran a set of wheels on my 94 Accord and also on my 240Z. I'm partly wrong, you are correct. The larger Honda's, Accord and Prelude, did have 4 x 144.3 but the offset was for front drive and probably required a spacer. All the Civic based cars had the 4 x 100. Quote Link to comment Share on other sites More sharing options...
kimsarah Posted February 5, 2009 Share Posted February 5, 2009 Brilliant, can't wait to get my hands on one of those new Honda Civic Coupe Quote Link to comment Share on other sites More sharing options...
freakshow Posted February 5, 2009 Share Posted February 5, 2009 I have a set of wheels that my brother in law was running on his infiniti m30, with wheel spacers. The spacers werent wide enough and the wheel weights rubbed off, and put gouges in the strut tubes. I tried the wheels on my 92 honda accord, perfect fit. The bolt pattern is the same, the offset is not. To run the whels on my 79 zx, I would have to have almost two inch spacers. This was the plan until i picked up a set of factory z alloys. The honda wheels looked sweet when i did the mockup, and I might go that route later. Long story short, accord wheels share the bolt pattern, not the offset, gotta get wide, very wide spacers. Quote Link to comment Share on other sites More sharing options...
tonycharger72 Posted February 10, 2009 Share Posted February 10, 2009 Honda's like most modern cars, have a high postive offset - somewhere from 38p-45p, Z's have a 15p offset, have to run at least a 25mm spacer to make these wheels fit, Also, being 25mm spacers they have to be the kind that will bolt to the hub and then the wheels bolt to the the spacers - not the kind that just slips on and is sandwitched between the wheel and the hub as your wheel studs wont last long and you will lose a wheel!!! And, Need to make sure the spacers you run are correctly matched to the Z hubs, I ran spacers on an old Ford Fairlane, which weren't located properly on the hub, centre was to large so eventually the studs broke and almost lost a wheel !!! Quote Link to comment Share on other sites More sharing options...
TxTechZ Posted February 13, 2009 Share Posted February 13, 2009 I need to clarify the offset of a 280Z. Is it 0 or is it +15. I have gotten both answers from different sources. I am trying to fit some wheels with +45 offset and looking to make sure I get the correct size of spacer/adapter. Quote Link to comment Share on other sites More sharing options...
tonycharger72 Posted February 13, 2009 Share Posted February 13, 2009 Well I think its 15p, mostly because the Z wheels I have measured all showed a 15p offset - those stock steel rims with the "Z" hubcaps! Also, once I go to a 0 offset and 7" rim, the wheels are poking out past the guards, however, others have the experience of fitting 7-7.5 rims with close to 0 or even small negative offsets and the wheels still stick under the guards................... So it might be a bit of a lottery !!! Best thing to do is measure you own car, or measure the wheels that are on there at the moment, that is, if they fit !!! That will give you a much better indication of what offset you should choose for your car !!! Quote Link to comment Share on other sites More sharing options...
