chicostyle Posted January 13, 2009 Share Posted January 13, 2009 Hye, In advance sorry for my english, i'm french I have a 260Z 2+2 with rotawheels in 17*9.5 I've decided to mod my L26 I bought a head from a race english car company "samuri" http://www.samuri.eu/ It's a E88 head E88 with 44mm inlet valves, 35mm exhaust valves and a combustion chamber of 38cc. After more and more reflection, i have two solutions: Stock L26 with L24 pistons overbore 0.040 (+1mm) and "cut-outs" for the valves after verification, It is going to be 2627cc with 10.74:1 or L26 with L24 rods/crank and L28 flat top pistons (86mm) It's going to be a "short stroke" engine for more RPM 2563cc with 10.56:1 but it's more expensive €€€€ A L28 in France is a difficult find, otherwise I would be on the block with L28 for this preparation. What do you think? Any input, suggestions w/e are appreciated! Quote Link to comment Share on other sites More sharing options...
2fast2Z Posted January 13, 2009 Share Posted January 13, 2009 If you de stroke your L26 with L24 crank and rods you will have a L24, no more no less and you can't install L28 pistons unless you have your block bored out, the L24/26 have a stock bore of 83 and L28 have a 86 m.m. bore. What about searching after a 2.8 patrol engine it is also a L28, then you can de stroke it with L24 rods and crank. Why a .040 over bore instead of .020 ? If your L26 is the matching engine then you should stick with it and search after a L28, maybe there is some from europe having a container shipped from US or you can search ebay.de, they show up once in a while. Chris Quote Link to comment Share on other sites More sharing options...
chicostyle Posted January 14, 2009 Author Share Posted January 14, 2009 "An L24 and L26 block can be bored to a max of 86mm and an L28 to 89mm. Pistons must not come out the top of the block more than .12mm or 5 thou." Dave Jarman You say: "Why a .040 over bore instead of .020 ?" Just for more CC Thanks for the ebay.de, I go directly for searching a L28. Quote Link to comment Share on other sites More sharing options...
pjo046 Posted January 14, 2009 Share Posted January 14, 2009 Nice looking car!!! But I'd mount a bumper in the front, and paint the grille and the rear plate black. Perhaps also a bumper in the rear. Just my personal opinion, no offense! Is this going to be a high-rpm race-engine? If not, then I wouldn't change to shorter rods and a L24 crankshaft. What you gain in response and high-rpm power you loose in low end torque and street-driveability. You haven't considered turbocharging? Just asking. That is by far the easiest way to get some serious power. I am going the other way though, basically because it is hard to get the turbo-build approved in norway. Quote Link to comment Share on other sites More sharing options...
chicostyle Posted January 16, 2009 Author Share Posted January 16, 2009 Nice looking car!!! But I'd mount a bumper in the front, and paint the grille and the rear plate black. Perhaps also a bumper in the rear. Just my personal opinion, no offense! Is this going to be a high-rpm race-engine? If not, then I wouldn't change to shorter rods and a L24 crankshaft. What you gain in response and high-rpm power you loose in low end torque and street-driveability. You haven't considered turbocharging? Just asking. That is by far the easiest way to get some serious power. I am going the other way though, basically because it is hard to get the turbo-build approved in norway. I prefer a N/A preparation I'don't like the turbocharching solution I think choose the solution with Stock L26 with L24 pistons for the moment. If I find a L28 later, I put his head above Quote Link to comment Share on other sites More sharing options...
Daeron Posted January 16, 2009 Share Posted January 16, 2009 why not just bore the engine you have to 86mm, and run a stock L28 crankshaft and stock L28 pistons? The 2.8 geometry really is pretty well super... 2.8 liters with twin SUs or triple webers and electronic ignition is a GREAT motor to throw into a Z; it has logged billions of miles and who KNOWS how many smiles in the last 35+ years and proven its worth. I understand the desire to do something less typical.. but sometimes going the tried and true method is simplest and wisest. Quote Link to comment Share on other sites More sharing options...
chicostyle Posted January 16, 2009 Author Share Posted January 16, 2009 Why not. For information the crank L28 and conrod L28 are really the same of L26. But rebore a L26 in 2.8 L (86mm) is still difficult, because ultimately the thickness of metal will be lower than standard L28. Quote Link to comment Share on other sites More sharing options...
2fast2Z Posted January 16, 2009 Share Posted January 16, 2009 Guys, this is becoming a very rare car in europe, you have to remember that. Do not bore that block, unless it is needed, i have the matching L24 and it is getting re build to stock and bored due to wear, i got it bored .020 over so there is plenty to go up a size if needed. If you want more power, slap in another motor, but keep that matching one or your car will loose value. Chris Quote Link to comment Share on other sites More sharing options...
