1979280zx Posted February 3, 2009 Author Share Posted February 3, 2009 i change ever thing an it still dont run gettin gas got spark fuel presser is 36 dont no whats wrong with it Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 4, 2009 Author Share Posted February 4, 2009 could the motor be getting to much gas an thats why it wont run Quote Link to comment Share on other sites More sharing options...
ckolander Posted February 4, 2009 Share Posted February 4, 2009 Hit it with a hammer, fixes everything Quote Link to comment Share on other sites More sharing options...
S130Z Posted February 4, 2009 Share Posted February 4, 2009 PLEASE can you use some correct spelling and punctuation? I have had 6 beers in the past hour and I am doing a better job at that than you. Lets start from scrap. Does the car run at all? If so, how long? Have you checked all of your sensors? Did you install the distributor pointing in the correct direction? Turn your motor to TDC on #1 and tell us what position your distributor arm is point in. Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 4, 2009 Author Share Posted February 4, 2009 the motor don't run. now if you hold it full throttle it try's to run.the distributor point's at the number one plug wire.now if i let the car sit for awhile an then try to start it it back fires.i rebuilt the motor an set every thing up like the chilton's said. Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 5, 2009 Author Share Posted February 5, 2009 im going to get a video of the motor today to see if that will help you guys help me Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted February 5, 2009 Share Posted February 5, 2009 Cam out of time 180 degrees? It might be pointing at cylinder 1 but I would pull the valve cover and see if the cylinder 1 cam lobes are facing up. If not, do what was suggested above by re-indexing the oil pump shaft. Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 5, 2009 Author Share Posted February 5, 2009 ok will check Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 5, 2009 Author Share Posted February 5, 2009 got sum pics uploading now Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 5, 2009 Author Share Posted February 5, 2009 here the pics Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 6, 2009 Author Share Posted February 6, 2009 this motors got me so mad im ready to sell it an put a small block chevy in it Quote Link to comment Share on other sites More sharing options...
S130Z Posted February 6, 2009 Share Posted February 6, 2009 1979280zx said: this motors got me so mad im ready to sell it an put a small block chevy in it Now that's what I'm talking about! That would fix all of your problems. Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 6, 2009 Author Share Posted February 6, 2009 think bout it how much could i get for the motor i have. it rebuilt new rings new bearings gaskets heads been port an polished lapped the valves Quote Link to comment Share on other sites More sharing options...
S130Z Posted February 6, 2009 Share Posted February 6, 2009 $200-$300 bucks. Quote Link to comment Share on other sites More sharing options...
1979280zx Posted February 6, 2009 Author Share Posted February 6, 2009 sh*t i got more then that in it. i would just keep it an still do the swap. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted February 6, 2009 Share Posted February 6, 2009 Just pull your distributor and turn the rotor 180° and reinstall. I turns at half the speed of the crank. Just because the rotor is lined up with #1 and the timing mark no the crank in can still be 180 out. You can also just move the spark plug wires around 180 on the distributor cap and get the same results. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted February 6, 2009 Share Posted February 6, 2009 I doubt he needs that since the lobes of the cam are up instead of down when the rotor is pointed at number one...........unless his spark plug wires are not in the right holes. Quote Link to comment Share on other sites More sharing options...
