turborust Posted January 27, 2009 Share Posted January 27, 2009 I am looking to buy the V-band clamp, that holds the exhaust turbine housing onto the rest of the turbo, from any of these holset turbos. hy35 / hx30 / hx32 / he351 So if you have a junk turbo lying around, let me know. I may also be interested in buying the exhaust turbine housing from the hy35, v clamp style only. Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted January 27, 2009 Share Posted January 27, 2009 the cummins v-band clamp that come on those things are tiny and junk, they strip or break easily over time from the heat a normal gas engine produces, it wears on them quickly versus the cooler running diesels. I recommend you get a stainless steel one from here, that's what I used... http://www.burnsstainless.com/cgi-bin/order.py?action=add&part_number=VB-400%20Clamp Yes, a little pricey you might think, but definitely worth it. Actually, I might have a spare 1 I could sell you for $45 shipped Quote Link to comment Share on other sites More sharing options...
turborust Posted January 27, 2009 Author Share Posted January 27, 2009 I have bought one from them but the clamp is too wide to fit properly. Plus the 4 inch clamp would only work on the exhaust side for the down pipe, and the 3.5 inch clamp is just a bit to big. So I need something that is around 3 1/4 diameter and approx 18mm wide. Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted January 27, 2009 Share Posted January 27, 2009 it's not to wide to clamp the downpipe to the housing, I recommend that upgrade, works great when I did it. but now I see, you're looking for the middle clamp. Yeah, I never had to replace that one, sorry. The best bet is to call Cummins and order it new, that way you don't get a prematurely used one that's going to crap out on you as well. Cummins.com Quote Link to comment Share on other sites More sharing options...
big-phil Posted January 27, 2009 Share Posted January 27, 2009 the cummins v-band clamp that come on those things are tiny and junk, they strip or break easily over time from the heat a normal gas engine produces, it wears on them quickly versus the cooler running diesels. I recommend you get a stainless steel one from here, that's what I used... http://www.burnsstainless.com/cgi-bin/order.py?action=add&part_number=VB-400%20Clamp Yes, a little pricey you might think, but definitely worth it. Actually, I might have a spare 1 I could sell you for $45 shipped I broke and re welded the bolt on one of mine. I would get the upgraded one. Quote Link to comment Share on other sites More sharing options...
turborust Posted January 27, 2009 Author Share Posted January 27, 2009 I've contacted the local holset dealer yesterday and I have to have a min of $100 +shipping order and the clamp is only $25. So before I go this route I am looking to see if anyone here has one. Quote Link to comment Share on other sites More sharing options...
turborust Posted February 12, 2009 Author Share Posted February 12, 2009 Still looking for the v clamp that holds the exhaust housing to the turbine center section Quote Link to comment Share on other sites More sharing options...
GrayZee Posted February 12, 2009 Share Posted February 12, 2009 I was looking for a vband to fit my exhaust DP, I paid over $100 from the Dodge dealer for one and then a friend told me about a local store that sold air filters and such for heavy trucks that might have something like that.. I ended up driving down there and the guy took one look at my Hy35 and knew exactly what I wanted (including the part #) It was $20! Seeing I never even used the Dodge one yet I returned it and got my $100 bucks back. Perhaps you can find a local business that help you? The store in my city is Ideal filter and supply in case you are interested. (204) 697-4332 Quote Link to comment Share on other sites More sharing options...
turborust Posted February 12, 2009 Author Share Posted February 12, 2009 Looking for the V Clamp that goes right next to the oil supply and return on the center section of the turbine housing. This connects the exhaust housing to the turbine center section. I already have the 4" v clamp for the exhaust. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted February 12, 2009 Share Posted February 12, 2009 Looking for the V Clamp that goes right next to the oil supply and return on the center section of the turbine housing. This connects the exhaust housing to the turbine center section. I already have the 4" v clamp for the exhaust. dude, I understand that... but they have vbands in MANY sizes... Quote Link to comment Share on other sites More sharing options...
