injector wiring
So I was installing a new manifold gasket and decided to install new seals and electrical connectors also. When I was taking it apart I was kinda dumb and cut the injector connectors thinking "oh well I'm just gonna put new connectors on anyways".
Now I'm looking at the wires and they're both black. Does it matter which way the two wires are installed into the connectors??? If so how do I figure out which is which...
Thanks for your help.
Josh
Seperate the wires and turn the ignition on. You should get a good 12V on one wire measured against ground (or batt. neg.) Although on the stock injectors it might not matter, you also might not want to take the risk. If you ever plan on upgrading to decent injectors you'll want the polarity right.
