clutch+flywheel
zx beast
Yep, direct swap, just did it my self. Make sure it is a 2plus2 or turbo flywheel. Specify that when getting the clutch and pressure plate.
N/a 225mm
turbo/2plus2 240mm
Dose not seem like much, but when you compare it is big.
It is measured by diamater.
BTW, I had mine lighten, gives things a little more Zing!
Woldson, did you use the same collar or did you have to buy a 2+2 or turbo one?
Thanks
N/a 225mm
turbo/2plus2 240mm
Now even though I just did this I'm at a lose to the word "collar".
If you mean throw out bering, it is the same. If you mean poilet shaft bearing, it is the same.
I could seach "collar" and get you answer, but I might get lucky with my wife tonite, so gotta go. :)
BTW lighten the flywheel, yaa big diff.
6.5lbs.
You want the weight to removed futher out.
This will have the greatest effect and limit possible failure where the flywheel bolts up to the crank.
Get the fly wheel and pressure plate balenced as well.
For me it was so worth the money. Smooth, reposive, and no problem what so ever on take off.
Read up on a thread that was titled, lighten flywheel.
I perfer TonyD's take on this situation.
Oh one other thing, I kinda have to watch the rpms now.
Around 4k plus the car would have sight vibration.
Now me no feel engine in pedals or car. Almost feels like,,,,,,,,like........a honda 4banger....There I said it!!!! The engine dose not feel so heavy, it's more nimble.
