Gear Lube Blowing Out of R200 Vent Hole
Miles
I had this very same problem for about 2 years. Then one day I popped one of the half-shafts out of the side (the car was up on jacks, but level), and oil poured out. It was not even a cup of oil, but after I reinstalled the shaft, I found that I never had problems with oil blowing out the top vent tube any more. I guess I had put too much oil into the case when I installed it. I am still perplexed as to why a slight overfill would cause oil to vent out though. The vent tube is baffled, so this still puzzles me.
Overfill of gear lube makes sense. The problem seems to have gone away. The gear lube got onto the exhaust pipe and left some burnt oil stains. I'll be more careful next time I change the gearlube. Also, the plastic pipe that goes into the vent hole broke off so I may try to work some tubing into the hole and route it so it drains to the ground.
Thanks
Miles
