how to clean rust off brakes
Ok, so I grabbed a set of the front brakes from silverminemotors.com. I gotta say, these are pretty. The only thing is that there is a little bit of rust on one of the rotors. Do I need to clean this off before installation and if so, what's the best way to do it? Thanks for the help guys.
Soak it in some vinegar and it will wipe off with a wet rag in the morning :)
Overnight should be able to take car of anything you probably have and less time is probably sufficient. The less time they spend in there, the better.
As long as you don't have any pitting or scoring you should be good to go.
If there is minor imperfections, they can be turned, but if there is anything after a wipe-down I would be contacting the seller.
