DB4/5 Nose & Bonnet Mod
misterZ
It could work. Wheelbase is a little longer. Here are some measurements for you:
1963 Aston Martin DB5:
Wheelbase 2489 mm 98 in
Track front 1372 mm 54 in
rear 1359 mm 53.5 in
Length 4572 mm 180 in
Width 1676 mm 66 in
Height 1346 mm 53 in
Length:wheelbase ratio 1.84
Ground clearance 152 mm 6 in
Kerb weight 1465 kg 3230 lb
Weight distribution
(Front) 50.80 %
Fuel capacity 86.4 litres 19 UK Gal 22.8 US Gal
Chassis:
Engine location Front
Engine alignment Longitudinal
Drive RWD
Steering rack & pinion
Suspension front Independent wishbone coil spring anti-roll bar
rear Live axle coil sping
Wheels front 5.5 x 15
rear 5.5 x 15
Tyres front Avon Turbospeed 6.70-15
rear Avon Turbospeed 6.70-15
Brakes F/R Disc/Disc-Servo assist
disc dia. front 292 mm / rear 274 mm
Engine:
Bore × stroke 96.00 mm × 92.00 mm
3.78 in × 3.62 in
Cylinders S-6
Displacement 4 litre
3996 cc
(243.851 cu in)
Type DOHC 2 valves per cylinder
12 valves in total
Sump Wet sumped
Compression ratio 8.80:1
Fuel system 3 SU HD8 carburettors
Maximum power 285.9 PS (282.0 bhp) (210.3 kW)
@ 5500 rpm
Specific output 70.6 bhp/litre
1.16 bhp/cu in
Maximum torque 390.0 Nm (288 ft·lb) (39.8 kgm)
@ 3850 rpm
bmep 1226.4 kPa (177.9 psi)
Specific torque 97.6 Nm/litre
Coolant Water
Bore/stroke ratio 1.04
Unitary capacity 666 cc/cylinder
Aspiration Normal
Transmission 5spd Manual
Top gear ratio 0.83
Final drive ratio 3.77
Performance:
0-50 mph (80 km/h) 6.40 s
0-60 mph 8.10 s
0-100 km/h
0-100 mph 25.70 s
80-120 km/h (50-70 mph) in top
Standing ¼mile 16.00 s
Standing km
Top speed 229 km/h (142 mph)
Power-to-weight 192.49 bhp/ton
