boostedZ Posted March 3, 2009 Share Posted March 3, 2009 im new to datsun, and just wanted some help on this. i need to flush my transmission, but don't know how to find it or do it on this car. can someone please help me with how to do it and locate it please thank you in advance. Kevin Quote Link to comment Share on other sites More sharing options...
woldson Posted March 3, 2009 Share Posted March 3, 2009 (edited) Go to a parts yard, get a five speed,,, Remove auto, install manual! Edited March 3, 2009 by woldson infactuation with manuel is too apparent! Quote Link to comment Share on other sites More sharing options...
attworth Posted March 3, 2009 Share Posted March 3, 2009 Oh dear. There should be a rule on all car forums that you must consult a service manual before becoming a member. http://www.xenons130.com/reference.html Quote Link to comment Share on other sites More sharing options...
boostedZ Posted March 3, 2009 Author Share Posted March 3, 2009 the car is already a 5-speed. anyone else have some info for me thanks and i got the car with no service manual Quote Link to comment Share on other sites More sharing options...
skib Posted March 3, 2009 Share Posted March 3, 2009 the car is already a 5-speed. anyone else have some info for methanks and i got the car with no service manual http://www.xenons130.com/reference.html theres a link to online manuals right there^ its a good habbit to mention the car/motor/trans your running when asking tech questions, cuz the more info you can give the better answers you can get. helps us help you. another over all good place to start is the search button, you can even click the one in my sig if your not sure how to use it. Quote Link to comment Share on other sites More sharing options...
attworth Posted March 3, 2009 Share Posted March 3, 2009 the car is already a 5-speed. anyone else have some info for methanks and i got the car with no service manual Should have specified that the link in my post was for the service manual. Find the year you need and download it. It'll be a great tool. If you've got a manual transmission, you shouldn't need to "flush it." There's a drain plug on bottom and a fill plug on top. Make sure you can get the fill plug off before you drain it. The rest should be self explanatory. There's a chart with recommended fluids and quantities in the service manual. http://www.xenons130.com/reference.html Quote Link to comment Share on other sites More sharing options...
boostedZ Posted March 3, 2009 Author Share Posted March 3, 2009 okay thanks guy, so take off the fill plug first then the drain plug. i'll try that Quote Link to comment Share on other sites More sharing options...
JustChou Posted March 3, 2009 Share Posted March 3, 2009 You will likely have to get a little hand pump to pump ATF or whatever you use into the trans. Check the manual for fluid recommendations. Please drain the oil into a pan and bring it to a local oil changer for recycling. They are required by law to take it free of charge. Quote Link to comment Share on other sites More sharing options...
