Fuel Tank Vapour Tank
Mike Rowe
I need new hoses to the vapour tank, but they are either not available or outrageously expensive.
What have others done?
Can you do without the vapour tank? If so what did you do with the outlets on the fuel tank itself?
Otherwise have you found hoses to fit the vapour tank?
Is the vapour tank pressurised with the RB system in?
  • 4 weeks later...
I plugged all of the hose holes in the main fuel tank leading to the vapour tank. Then I fitted a UK fuel tank filler pipe breather - all it does is route a single feed from the filler neck through the wheel well out to ground. If I overfill it now then excess fuel will start to dribble out at my feet. No problems so far with this setup.
