Need help with aftermarket suspension springs and ka motor swap, not level.
Hi, i have a 240z that i swapped a ka24de. I installed some used Blue lowering springs but have no idea what kind they are. I installed the ones with the thicker windings on the rear, and the thinner coils on the front. Is this correct? both springs look the same and have the same hight so i just assumed this was the right way. Am I being retarded? Can you help me identify these blue springs? Someone told me they might be suspension techniques.
Second, The ride hight is about 3-1/4" inches in front, and 1-1/2" inches measuring wheel well gap from tire to the fender well. Is this because of the lighter weight of the ka24de, or is this because i installed the springs backwards? thank you!
the ka is mounted towards the firewall. and the body is stripped. thanks for your help!
You have done nothing that some body else has probably already done. Imitation is the highest form of flatter/compliment. Chances are you learned to do something on your build by reading what others have shared on this forum.
