Guest Anonymous Posted December 27, 2002 Share Posted December 27, 2002 Last week my 78 200sx driver lost a U joint.So I call the parts house and they tell me that the drive shaft is not servicable.I look in the MSA catalog and they say the same thing about the Z,thru a few years.Has anyone tried to press one of these apart?Am I at the mercy of the driveline shop?I have a few shafts from other datsuns,but it would be a lot easier to fix the one in the car,than to make one and have it balanced.Any thoughts? The sooner I get it fixed,the sooner I get back to the Z. Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 28, 2002 Share Posted December 28, 2002 any driveshaft shop can replace those u joints, they may charge a little more, but they can do it. if a driveshaft shop trys to say they cant, they are weak. Quote Link to comment Share on other sites More sharing options...
Mike C Posted December 28, 2002 Share Posted December 28, 2002 I'm not sure that they can be replaced except by an extremely good driveline shop. In looking at the non-replaceable u-joint driveshafts I have, the u-joints are staked into the yoke and there is no groove for a circlip. If the stakes are ground and the yoke machined for circlips, they can be rebuilt. Machine work will eat you up however. Probably best to have a custom driveshaft made unless a new one from Nissan is cheaper. For a 280 you can get a 240 driveshaft where they ARE replaceable, don't know about your 200. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 28, 2002 Share Posted December 28, 2002 Thanks for the replies,I was thinking about machining some grooves myself,(I run a CNC lathe for a living) but its probably easier to shorten a longer drive shaft and have it ballanced.I would have to cut it apart to grab on to the side of it ,or get one of the mill guys to use a wheel cutter.I was really hoping the parts house was mistaken.I have an 84 pickup for parts,I'll size it up in the morning. Quote Link to comment Share on other sites More sharing options...
