missing heat shield
chopstic
After my 280z is warmed up it has a hard time restarting and runs VERY rough for the first few minutes. I've been told that I am missing the heat shield, and because of this the injectors are getting heat soaked and thus causing the problem. Does anyone have a picture of the heat shield i need?
My 2 Cents:
If it runs very rough for the first few minutes the injectors would not be running rough because of them being 'heat soaked' because it couldn't reach that high of a temperature that quickly. Check to make sure the injectors aren't touching anything that could possibly be making them heat up abnormally.
I have this same problem, but I don't think its the injectors that are the issue. I think its the fuel inside the rail and fuel lines that begin to boil and air bubbles begin to form. It runs like crap until they go away. Just my opinion of whats happening. I'm also missing a heat shield.
  Gilli said:
He said in the first couple of minutes.
So, does he mean:
"once my car is warmed up and I try to restart it, it doesnt want to start and will run rough for a few minutes." OR...
"my car runs rough for the first few minutes till its warmed up, then it has a hard time restarting."
Seems kind of obvious to me that its the first one or he isnt communicating very well.
If he means what he wrote, when the fuel isnt moving it will pick up alot of heat from the engine compared to the fuel continually being run through the lines, through the tank, etc. So when he stops the car and goes to restart it the fuel has gotten hotter and as srbigbutt said, the fuel can boil until it has cooled off sufficiently by running through the fuel system. Thats my best guess.
so, for a test, why not get some heat resistant matting, and wrap your fuel rail in it.
Insulate it from the heat, to try an eliminate any fuel boiling issue.
If that works, either replace the heat shield, or look for a more permanent insulation method.
  chopstic said:
correct... it only happens when the engine is already warmed up.... like when i stop to get gas and then restart it afterwards.
try wrapping your rail in some heat wrap, thats what I did for my L26
I tried this but don't think I did a very good job. Stock rail is very akward to wrap. I ended up taking it off because it didn't work and I didn't like the way it looked. I will probably soon be getting a new aftermarket fuel rail and see if that helps.
