ZXT_bean Posted March 19, 2009 Share Posted March 19, 2009 Ok well lets start from the beginning. I have a trigger wheel setup purchased from derek here on the forums. basically im just trying to make sure my wiring is all correct. Ive pulled the spout plug hoping to put it into limp mode. Ive tried switching the vr sensor wires 3 times. ive plugged in 3 different edis modules. ive wired it per the megamanual. if I have the moduel grounded and it has power, if I pull the spout connector I should have spark during cranking correct? ive even pulled apart the entire vr sensor wire and re-shielded it. still im having no luck. I dont know what to try next! I have yet to even bring the MS near the car as im still trying to verify wiring and dont want to mess anything up. Quote Link to comment Share on other sites More sharing options...
SidWell Posted March 19, 2009 Share Posted March 19, 2009 How do you know you have no spark? Are you looking for it with a timing light? Do you have access to an oscilloscope? You can troubleshoot many MS issues with an o'scope. You can find older dual trace o'scopes on eBay for less than $200. The hours you will save getting your setup to work is well worth the investment. The first question is the polarity of the VR sensor on pins 5&6. If you are not 100% sure you have that correct you will have a hard time going much further. I am not sure what you mean by spout plug. If you don't have the MS installed yet, the unit has to be completely wired with the exception of pins 1%3. This will simulate the limp home mode. You can even hook up the MS and not hook up pin 3, this also will simulate the limp home mode. The nice thing about that is you can see if you have a tach pulse in MegaTune. Maybe if you submit a picture or two, that may help. Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted March 20, 2009 Author Share Posted March 20, 2009 well i have not gotten out the timing light as of yet.. I have an inline spark tester, and I have yet to see it light up. by the spout connector I mean what I have circled in red. I have pins 1 and 3 wired up to my MS harness. but the unit has yet to be plugged into the car. i know i have 12v at the module, the coil and the ground capacitor. I have all 3 of my coils wired accordingly. I do have the polarity of the VR sensor wires reversed currently because i have my sensor mounted backwards. I dont know if thats going to end up being my problem or not. like I said I dont know what to do next. Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted March 20, 2009 Author Share Posted March 20, 2009 i just came across this wiring diagram. im not using pin 4 for anything.. should i be? http://forums.hybridz.org/showthread.php?t=122394&highlight=edis+wiring Quote Link to comment Share on other sites More sharing options...
SidWell Posted March 20, 2009 Share Posted March 20, 2009 I do have the polarity of the VR sensor wires reversed currently because i have my sensor mounted backwards. There is your first problem. Unless it is wired right, nothing will work. A bit of advice; Do not run your VR wires close to the alternator. That alternator puts out lots of electromagnetic noise. Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted March 20, 2009 Author Share Posted March 20, 2009 well I have tired the wires both ways. and at the moment, i dont even have the alternator in the car. I will try reversing the wires yet again and see if does anything. Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted March 20, 2009 Author Share Posted March 20, 2009 ok so if pin #9should be connected to ground via a 1N4003 diode, does that mean that pin 4 should just go to ground itself? Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted March 20, 2009 Author Share Posted March 20, 2009 ok i just went outside and swapped the wires around, and kaboom just like that.. I have SPARK! do you still think i should put in the 1N4003 diode just for safe measure? Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted March 20, 2009 Author Share Posted March 20, 2009 If I was to post a copy of my msq. file would anyone be kind enough to go through it and check for any issues. I dont want to try and start the car and some how accidentally pop the motor lol Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted March 20, 2009 Author Share Posted March 20, 2009 Also im planning on using a 4 wire bosch o2 sensor. but im puzzled as how to wire it up. two white wires, these are for the o2 heater and go to 12v+ one grey wire, this goes to ground and one black wire, this is the signal wire to the MS any thoughts, ive looked but havent found any specific or 100% truthful info. Quote Link to comment Share on other sites More sharing options...
softopz Posted March 21, 2009 Share Posted March 21, 2009 what do you have for your spark setting in megatune. Would be nice to know the firmware used and megatune hardware. Going backwards Do you have the proper jumpers on the board? Quote Link to comment Share on other sites More sharing options...
