Hood clearance
Ive got a sbc mounted with the JTR mounts with a edelbrock performer RPM intake manifold and a holley 4160 what air filter will fit if any under the stock hood? From what I have seen from searching, everyone either has the torker or the performer manifolds and can fit a drop base air cleaner witch is what i want to do.
Has anyone got any type air filter setup that will clear the stock hood using a perfromer RPM?
thanks
I used:
-JTR engine mounts,
- Professional Products "Crosswind" copy of the Edelbrock Airgap RPM (not sure if the carb flange height is exactly the same),
DID NOT USE THE JTR 1/2" spacers between frame rails and crossmember
I used a 1/2" (divided, wood) spacer under the Holley 830 HP carb
(to get the air cleaner to clear the extended thermostat housing to get a radiator cap above the thermostat at the highest point to bleed air)
My air cleaner is the Moroso 14x3 dropped base.
I have VERY LITTLE clearance, less than 1/4", but it does not hit the stock hood.
