delorean6584 Posted April 1, 2009 Share Posted April 1, 2009 hi all ! i'm building my megasquirt for my stock l28et and i'm in the process of connecting the injectors, i have ms2 v3.0 there is alot of confusion about injector impedance and using dropping resistors ? i read somewhere that the ms2 ecu can handle both but anybody had great experience with that? thanks yan N.B this week i will post pics of my 280zx freshly painted with hybridZ logo on it hehe Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 1, 2009 Share Posted April 1, 2009 Using the resistors makes it easier, and takes out any possibility of toasting them while you figure out the correct PWM settings. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted April 1, 2009 Share Posted April 1, 2009 Or you could use racingmini_mtl's P&H injector boards to get everything you can out of the injectors. (faster response time for bigg injectors (assuming turbo app and large injectors - more granularity)... Quote Link to comment Share on other sites More sharing options...
delorean6584 Posted April 2, 2009 Author Share Posted April 2, 2009 anybody have a shematic of how to wire it up ? i dont have any resistor now but could buy some from radioshack then make my own... but i dont have any value or how to connect it ? yan Quote Link to comment Share on other sites More sharing options...
delorean6584 Posted April 4, 2009 Author Share Posted April 4, 2009 would it be easier to get 81 resistors? or i only needs like 2-3 standard resistors Quote Link to comment Share on other sites More sharing options...
TONY C Posted April 4, 2009 Share Posted April 4, 2009 just wire in your factory resistors. They already fit in the car, are the correct resister, weatherproof, and have a quality plug. If you are making a new wire harness you can remove the old spade connectors from the plug and put new in. I have used mine this way from the start and it works Great. Quote Link to comment Share on other sites More sharing options...
delorean6584 Posted April 4, 2009 Author Share Posted April 4, 2009 and is the stock resistor package a 2 wire plug-in ? and how i wire it up ? in parallel or series with the enjectors ? positive side ? Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted April 5, 2009 Share Posted April 5, 2009 Stock 1981 280zx turbo resistor uses 7 terminals. One supply and the six individual resisted outputs. Dropping resistors can be wired in anywhere between feed to the injectors. Quote Link to comment Share on other sites More sharing options...
delorean6584 Posted April 5, 2009 Author Share Posted April 5, 2009 ahhhh darn.... i had finished the injectors wiring.....so i need to cut all the 6 positive feed for the injectors to wire the resistor package... i had connected it like the 1983 stock l28et.... live and learn i guess Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted April 6, 2009 Share Posted April 6, 2009 I'm not sure the ecu cares whether resistors are on the positive or the negative side of the injectors since they are only there to limit current as seen by the drivers in the ecu. Care has to be taken if you're using any of the factory harness since many gang both the positive and negative sides of individual injectors together. Quote Link to comment Share on other sites More sharing options...
delorean6584 Posted April 6, 2009 Author Share Posted April 6, 2009 no i have a new custom wiring, but i had injectors 1-2-3 positive together and 4-5-6 pos together just like the original, they were supposed to be fused and thats all....now i have to split these wires and get each one out of the resistor pack Quote Link to comment Share on other sites More sharing options...
