Guest Anonymous Posted February 10, 2003 Share Posted February 10, 2003 What is the fluid capacity, I need to know because I can't get the fill plug out just the drain plug. Got to fill it up through the drain! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 10, 2003 Share Posted February 10, 2003 Removal is looking down, I don't think it will come out. Would covers but don't have a new gasket . Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 10, 2003 Share Posted February 10, 2003 You don't need a gasket. Just use red or blue RTV and clean both surfaces well, follow directions. I have never used a gasket on a diff cover. Mark Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted February 10, 2003 Share Posted February 10, 2003 The theoretical capacity of an R200 is 2.75 pints. Quote Link to comment Share on other sites More sharing options...
spotfitz Posted February 10, 2003 Share Posted February 10, 2003 Originally posted by Greimann:The theoretical capacity of an R200 is 2.75 pints. You have that exactly right. After putting in the recommended 2.75 pints I've been trying to figure out how much comes out the vent, each time I drive it. I guess the rear bushings will be well lubed for some unknown date in the future. I guess I should have figured on the extra mass of the phantom grip in determining the actual amount of lube, but I didn't think it would be that much of a difference. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 10, 2003 Share Posted February 10, 2003 1.5 quarts final answer, installed and done now Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted February 10, 2003 Share Posted February 10, 2003 I have had the same problem with my fill plug on my 75. I dropped the rear end and worked on it with an impact wrench and various other tools but the sucker would not budge. I have ordered a new cover and plugs from Courtesy Nissan in Texas. When it gets here then I can be a little more reckless with the thing and maybe just maybe get it off of there. Then I may sell the rear cover on ebay. When my new stuff arrives I will be putting a little anti seize on those suckers before they go in! Quote Link to comment Share on other sites More sharing options...
stony Posted February 11, 2003 Share Posted February 11, 2003 you need to get the fill plug out that is the only way to make sure you get enough or not too much fluid in there. I might be wrong but you may be able to squirt fluid thru the side via the axle hole. Is it stripped or what? If it is i would remove the cover and get it fixed. Its a PITA but iwll ensure you have the right amount of fluid Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 11, 2003 Share Posted February 11, 2003 Just replaceing a burnt up one it came out of the same car about a year and a half ago. It is in fine shape with the cover intalled waiting to go in, the fill plug has a small amount of damage to it but when I go to take it off the wrench feels as if its about to keep on goin without the fill plug moving. But here goes some more tuggin Quote Link to comment Share on other sites More sharing options...
